**Today Only 21/05/2013** DGM IPS-2701WPH 27" LED Monitor & Dell UltraSharp U3014 30" Widescreen LED
Had my DGM since 4th July from ocuk,brilliant monitor, stand is terrible, mush better on an arm:D
How did you get the stand off i am prob being thick but cant get it removed and dont want to force it.
post no 356
http://forums.overclockers.co.uk/showthread.php?t=18417986&highlight=dgm&page=5
Stand removal info
ok the first pic is when i put it back together, but first you need to remove the four screws along the bottom edge at the rear of the screen.
if you pull the stand a little you will see the front bezel will becoming detached slightly. there is a number of plastic clips around the edge so it will need a small amount of force, just go easy and take your time down each edge. use something thin like the edge of a ruler, a flat head screwdriver will likely damage the bezel.
when the front bezel if off, you see the lcd panel, but you need to get this out of the way. it is held in by 4 plastic clips - 2 on the left and 2 on the right. these are very easy just to push to the side to free the panel.
move the panel out of the way just enough to see the base. dont move the panel more than you have to.
these 2 screws hold the base in place
no more base :)
ergotron arm holds it with no problems
my ergotron thumb screws are too long for this vesa mount so i'll need to add some metal washer thingies to tighten things up. but so far so good.
