Is Corsair Vengeance Any Good?
19 May 2004
Horsham, West Sussex
I'm in a bit of a panic at the moment.
I am trying to upgrade my son's PC - should be easy enough but I work away from home during the week, so only have part of the weekends to play with.
This means that if I'm missing a part or need to change anything that adds a delay of a week.
Finally got opportunity to start assembling on Sunday and found that I couldn't get the memory I purchased to run very well at all. Ideally, I would like to have spent a few days playing with it but concious that I can't do anything until next weekend I felt I had to return it quickly to be within the DSR rules.
Also, knowing I needed to find a replacement before next weekend, I looked throuh the qualified memory list for the motherboard.
The list is mostly RAM that I have heard off but don't see for sale in the UK -GSkill, AData, Elixir, Kingmax, Mushkin. And for the more available brands, the specified parts aren't readily available in the UK.
The only ones listed that could easily be obtained is Corsair Vengeance.
To be honest, I wouldn't have picked it because of the silly heat spreaders, but because I needed to order something quickly and it is on the qualified list I went ahead and placed an order.
I'm beginning to wonder whether I've done the right thing - although I have ordered, it is for collection so it's not too late to change my mind.
It's quite old. I suspect that it's SPD will be sparse. I didn't really want a silly heatsink.
But on the other hand it is qualified RAM for the MoBo.
The height of the heatsink isn't a problem now or in the near to medium future - I guess if I ever did want to fit a big heatsink then I could remove the RAM heatsinks.
Cheers,
Nigel
Its usually stable at XMP yes. But is not great at overclocking past the given spec for it.
Just looking for something that runs stable as advertised to be honest.
Not looking to clock beyond.
Cheers,
Nigel
Same as above really - I run with the vengeance ram, personally I like the look of the heatsinks, it runs at the speed it quotes but really doesnt overclock - as stated already, one more thing, if your mentioning the heat spreaders - are you getting the high profile spreaders? if so you may have some clearance issues if your using a large heatsink and fan for cpu your cooling
Really good , and looks lovely! I dont know too much about overclocking ram and im pretty sure there is no real point to it you will never notice a difference in the real world. My low profile 1600mhz does me just grand
Vengeance series is above average in quality and performance, good for running on the modest XMP profiles and nothing else. They are not expensive either. They are perfect if the XMP specs suit you and you just want to "plug and play" them.
Corsair Vengeance is ideal, so much so l have 32gb of if in my desktop and laptop :)
Compare with Samsung green :rolleyes:
