After having a few water level thoughts and issues I spent an hour investigating my loop.
Firstly I squeezed all the tubes at around an inch away from my barbs with the system off, when i squeezed the outlet on my cpu block a big bubble appeared if you can imagine the size of a squashed penny and youl get the idea of what came out plus a couple pea sized bubbles on the inlet tube I frantically checked the area for signs of water but there were non. Thinking this was the problem i took the top off my res and fired her up the bubbles proceeded to enter my top rad and never to reappear then disaster 2 drips from the inlet of my top rad coming from my cpu, quickly powering the system off I attached a second zip tie to the barb and put the res top back on, after wrapping everything up in tissue paper fired the pump up, all was well again fortunately 2 minor marks on the tissue paper (less than a grain of rice all together) on the first test and then all clear on the second test after leaving it priming for half an hour.
Finally I then removed the cap off my res again and all was ok no leaks. So once again ive got a couple of questions.
1. When i run the res without the top off the water level in the res drops about 5mm over what it drops with the top on could this be an indication of a problem?
2. Would you expect now the bubble has cleared from my cpu block that the temperatures should be noticeably cooler as the dont appear to be, my radiators are getting warmer though.
3. The minor leak after shifting the air bubble again is this an indication of a problem in the loop as ive not had a leek before or is it cause of the pressure differences caused by the movement of the bubble.
4. Lastly the now missing bubble will it have managed to free itself with the scuffle ive gone back round the loop squeezing the tubing again without any air being moved about although this is all with the res top on should it be done with it off so the air has an escape route?
Once again thanks guys
Looks like a bad mount.
