- 7 Mar 2013
- Caistor
I suppose Seasonic is better right -.-?
If I took the GPU out of my PC, I have a 10 year old PSU which I could use to power my Sandybridge PC... I wouldn't want to, but I could.
I dont see the point of certifying a PSU to be compatible with Haswell...
Were PSU's ever 'officially certified' for Sandy/Ivy?
Haswell has a new even more power saving C state that cheap PSU's and older branded PSU's can't do.
as long as it makes it easier for consumers I guess..If I took the GPU out of my PC, I have a 10 year old PSU which I could use to power my Sandybridge PC... I wouldn't want to, but I could.
What PSU's aren't recommended then? I see a few people getting messed about if they are planning on upgrading?
I have a Corsair 860w Platnium, I'm guessing i'm in Haswell's good books?
EDIT: Table below says I'm all good!![]()
To our knowledge all mainboard vendors will disable this advanced power saving mode by default, and no customer upgrading to Haswell should experience any issues whatsoever.
Simply adding a single silent case fan to the system, connected to the power supply, should provide enough additional load to keep the system running in advanced power saving mode.
The only disadvantage would be that power savings in idle mode on such a system would only surmount to around 2-3W instead of ~5W.
So potentially an upgrader would need more than just a chip, board and RAM? WAT? Im running an old, but great Corsair VX450W on my rig which is either useless or will need some BIOS tweaks for a....... PSU? Come on Intel.. Should not be needed for a desktop chip. Im not worried about power usage!
You say that, but the XFX below 650w are not managing to be 100% Haswell ready, as is the same with other brands.
