** TITAN WATERCOOLING FITS GTX 780 **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
Important News
Our TITAN Graphics cards waterblocks fit GTX 780
I have added a note to the title of all TITAN blocks that are compatible with the GTX 780 to make it easier for customers to check.
We also have a special edition Tech Labs card out today
OcUK Tech Lab H2O Custom GTX 780 3072MB GDDR5
The OcUK Tech Lab H2O GTX 780 combines the fastest single GPU card on the planet with the most effective cooling solution.You can expand your visual real estate across three HD displays in jawdropping 3D and experience immense framerates with blistering graphics.
Featuring the Excellent GeForce GTX 780 2048MB, the OcUK Tech Lab H2O GTX 780 allows for incredible overclocking potential on an already outstanding graphics card.
This graphics card comes complete with your own choice of VGA block from industry leading manufacturers.
Choose the block that suits your own taste for a truly customised feel inside your system.
Never has a pre built watercooled card been such a complete package!
All of this cooling power would be wasted without the addition of the worlds leading cooling paste, a retail tube of Arctic Cooling MX-4 Thermal Compound (4g) is included with this package. The paste is applied to the GPU to maintain supreme performance with the GPU block.
The remainder of the paste will be sent with the card for future applications.
Specification:-
- GPU: GeForce GTX 780
- Core Base Clock: 863 MHz
- Core Boost Clock: 902 MHz
- Memory Clock: 6008 MHz
- Memory Size: 3072MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 2304
- Memory type: 64Mx32
- DirectX 11.1: Yes
- DVI Port: DVI-I /DVI-D
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 2yr
ORDER NOW
Truly immense overclocking ability with that waterblock fitted and OcUK is the first to offer water-cooled cards and can deliver within 1-2 days as we are manufacturing these cards as we speak. :)
Manufacturing or bolting blocks on and sticking coolers on the bay for extra dosh? Aha!
and does the block touch all the chips its meant to touch?
(i.e. the screws are in the same place but are the components the same size too?)
I can confirm it's a like for like match everything went on perfect.
And hopefully this means when the custom cooled 780gtx cards become available it will broaden the range of coolers for putting on my Titan without going down the WC route. I just want a decent air cooler than will fit in two slots, ta!
This is wrong on the store page too.
I think we all know what it's meant to be, but just to avoid confusion for those that don't I thought I'd point it out.
