Eyes failing you Greg, you old sod!![]()
I Ninja edited after seeing his response, about 30 seconds after clicking 'submit reply'. You young pups are far too quick for me
I wonder if any of the GK110's have a full 15 SMX's as that is what is theoretically available on the core.
Aye, it is very expensive to setup. PErhaps the biggest outlay are the SSD's, of which you need plenty in a RAID setup to reduce latency when capturing the video.
Frafs benchviewer is a much cheaper alternative although not quite as accurate (this is debatable) as using a dedicated capture card.
tbh I don't really look at all of the review sites I usually wait for anandtech review and go by that, they for me have always been good (no offence to other review teams)
Supposedly lasered off
I normally use Anand as well, good site.
Its better than using a system that no one can replicate, immunity is an unhealthy thing when its reviewers with the power to affect hardware sales are also dependant on revenue income from those selling / making hardware.
It just turns into a circus of which hardware maker is the highest bidder with no one being able to challenge their results.
Aye so I've been told. I guess the yield is so low going by the TITANs which as you know have 14 available. I just wondered if any cores actually had 15 functioning - a TITAN killer?
Agree wholeheartedly. I try and get my setup so it isn't a bottleneck but also represents what others can replicate at home. I could quite easily add 10 SSD's, 128GB of RAM and overclock the CPU to 5GHz but that isn't representative of what is the 'norm'. I don't use FCAT for that purpose. While it is arguably more accurate, using FRAPS and also by taking the 99th percentile gives us an accurate 'enough' reflection but also one which can be mirrored by everyone else at home for authenticity.
Thanks, I think as well as the usual "users own reviews" on forums like this, along side the normal FPS barometer reviews, latency is and should be just as important.
I think there probably is room for improvement in CF, given that AMD themselves have said they are working on it, but I also get a sense that its just a little exaggerated, and that some people are just using the better SLI performance to try and hammer home a point that doesn't really exist.
Especially when you see those driving this Latency thing, pcper. (which I believe is a good thing) have up until now completely ignored the problems that do show for the single GTX 680, except only now that the GTX 780 is out.
Yet with skyrim and the 7950 (which looks exactly like the GTX 680 latency in some games) they made a massive overblown issue out of it.
In fact I have never seen them be in anyway critical of Nvidia ever in recent times.
Reviewers being critical of hardware makers and pulling them up for problems is a very good thing, but when its completely one sided it makes you wonder who is providing them with revenue and what agreements maybe attached to that revenue.
Which in turn begs the question of accuracy and reality in their reviews.
What i found interesting in the vortez review was the max oc titan was slower than the max oc gtx780.
http://www.vortez.net/articles_pages/nvidia_gtx_780_review,10.html
