Unless the hijackers landed it after killing the pilot and now they are holding everyone at gun point with porcelain Glock 7s they smuggled through the metal detectors.
Step away from the WASD + LMB.
Kwerk. That is all.
We don't know what the incident was: fighter jets are scrambled when there is a bomb threat, when there is a hijack, when the wrong transponder code is used or if an aircraft cannot communicate with the ground. Often the result is when there is an unruly passenger on board.
"What is interesting in this case is that it would appear that the aircraft was only 10 minutes from landing - these are initial reports coming in - when they decided to divert to Stansted. So to actually change a destination 10 minutes from landing would certainly imply that there was some serious incident taking place."
Two men arrested for endangering an aircraft apparently.
Someone probably spilt a drink which has been blown out of all proportion into a major incident.
They may have simply had a ruck onboard or something as serious as trying to gain access to the cockpit.
Well Stansted is the UK airport on standby to receive all hijacked/terrorist threatened planes I believe, so it could be worse than simply because its from Pakistan.It's not big news that fighters are scrambled is it? Sort of thing that happens every month or so.
Seems to me it's only being mentioned because it's come from Pakistan. Just people being sensible and routine and it's become a news story.
Really?
I knew we had them on standby, I had no idea we scrambled them and redirected flights 10 mins from terminating to other airports every month :/
Two people are arrested after RAF Typhoon jets were launched to investigate an incident involving a passenger plane from Pakistan within UK airspace.
Two men are being held on suspicion of endangerment of an aircraft, Essex Police said.
