 - 16 Oct 2008
OK first off i have to say normally i buy my case fans from another shop as they have a great little graph where you can sort the fans in noise level, noise flow or RPM, however there choice is not great compared to other sites especially this one so i have come here for advice on what the best 140mm fan is for me in my situation.
My case is a Fractal Design Define XL with 10 hard drives in so far all of them are the old platter versions no SSD and there won't be for about another 6-9 months, I'm not an overclocker but it is important to me to keep my drives as cool as i can, having said that i don't want to sit next to a jet engine either so some kind of balance is needed, I'm also installing a Reeven Sixeyes fan controller my only reason going for this is because it will fit flush in the case when the door shuts.
OK this is what the manual says about the case:
2 front 120/140mm intake fans with removable, washable filter (one 140mm included, one optional)
1 top 180mm exhaust fan (included)
1 rear 120mm exhaust fan (included)
Now the 2 front currently have Fractal Design 140's and these need to be replaced with something new (over to you), the top 180 will stay standard and the rear 120 with be replaced with a Noctua NF-S12B (unless you tell me otherwise) only using that as i have one hanging around here, I think my fan controller will take 3 & 4 pin fans so i think i have most bases covered.
My rig is not that powerful it's just a E8400 @ 3Ghz with 8GB, not a gamer so fan less video card (6450), it will get upgraded but not for about another 8-12 months.
So over to you folks what are your suggestions? If you need any more infor from me just ask.
All1
All1
