3570k @stock, gtx 670 wf sli @stock.
Just testing my new sli setup, cards boost to 1189 and 1150mhz respectively. The former is my original purchased model. Capable of 1320mhz on the core, 7586mhz on the memory. Have yet to test the new card by itself.
i5 3570 @ stock clocks
Zotac GTX 670 OC @ stock clocks of 1136(boost)/1502
Score: 854
Apologies Kaap, ive added the core boost for each card, (both run differently) memory speed same on both.Could you confirm what clocks you are using please, stock clocks tend to vary depending on which model you have.
I like the blue cabling, it is the same as I use.![]()
Nice to see you went SLI Setter
How are you finding it? (sorry for OT Kaap).
Cabling wise, it's a mixture of bitfenix extensions and corsairs own pre braided modular cables. They dont go too badly together despite being totally different types of braid.
Heaven 4.0 screenshots are in .TGA format how is everyone converting them, or how are you capturing the screen to show the result and cobblestones.![]()
Do you use Precision or Afterburner ?
