- 17 Aug 2003
- Woburn Sand Dunes
the slot is the right size for a micro sim. the metal housing makes it look wider than it really is.
Can you post us a picture with the Micro SIM next to the slot it goes in on the S4?
I've got a 3.1amp dual socket one. Works great. The power is shared over both sockets, so that's the total amount you can draw.
yes, the process starts at bootup. zoomee said the process starts each time he turns the screen on. as i replied to him; mine does not do this. If I kill the process, it stays dead until i either use google play music or reboot the phone. the process is inactive when im not using play music anyway so im not bothered by it.
it's worth noting that people have reported that other apps can start the process so it might be something zoomee has installed. maybe.
Don't think about it!
Just hit the buy button!![]()
Ok, if you insist
Time to research some roms!
I assumed you may be semi old school enough to know the song - "the time has come to..... push the button"![]()
