Don't miss out on today's deals
Crucial RealSSD M4 256GB 2.5" SATA 6Gb/s Solid State Hard Drive (CT256M4SSD2) @ £134.99 inc VAT
Continuing the tradition of our award-winning solid-state drives, the Crucial m4 offers mobile and desktop users scorching-fast read and write speeds. Low power, lightweight, and durable, it empowers high-speed synchronous MLC NAND, advanced controller technology, optimized NAND management, and the SATA 6Gb/s interface. Together, that technology dramatically improves data transfers for bandwidth-demanding applications.
Our products are built on decades of design and manufacturing expertise. It is our expertise in NAND technology that enables us to optimize the performance and endurance necessary to build quality solid-state storage devices.
- Sequential Read (up to): 550MB/sec (SATA 6Gb/s)
- Sequential Write (up to): 300MB/sec (SATA 6Gb/s)
- Random 4k Read: 40,000 IOPS
- Random 4k Write: 50,000 IOPS
- PCMark Vantage: 65K HDD Test Score
- Interface: SATA 6Gbps / Backwards Compatible 3Gbps
- Native TRIM support
- Seek Time: .1ms
- Slim 2.5" Design
- 100.5 x 69.85 x 9.5mm
- Lightweight: 75g
- Operating Temp: 0°C ~ 70°C
- Storage Temp: -40°C ~ 85°C
- Low Power Consumption: 150 mW in operation, .85 mW in standby
- Shock Resistant up to 1500G
- RAID Support
- MTBF: 1.2 million hours
- Limited 3-Year Warranty
** FIRMWARE UPDATE 0309 - Increased speeds up to 550MB/s **
Link to Firmware: - http://www.crucial.com/support/firmware.aspx
Only £134.99 inc VAT.
ORDER NOW
Asus RT-N12E 300Mbps Black Diamond Eco Series Wireless Router @ £21.95 inc VAT
Save the planet and your pocket
Compared with generic Wireless-N routers, ASUS ECO-WiFi CPU reduces 72%* of energy consumption and utility cost
Extended Network Coverage
The RT-N12E features a 5dBi high-gain antenna that boosts the wireless signal, thereby extending coverage range.
Network Map-Manual Free Management
Straight-forward design to help users to:
Display the whole network status and clearly provide WAN/LAN status
Securely connect to your wireless network and prevent intruders from using it
Manage your network in minutes
Try our EZ UI software
• 300 Mbps high speed
• Plug-n-surf CD free installation
• External 5dBi antenna for better coverage
• Power saving: consumes less power during stand by mode
• Support EZ WPS connection
Network Standard: IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.3, IEEE 802.3u, IPv4
Data Rate 802.11b : 1, 2, 5.5, 11Mbps
802.11g : 6,9,12,18,24,36,48,54Mbps
802.11n : up to 300Mbps
Antenna: External dBi antenna x 2
*Antenna type will differ according to local regulations and requirement in each country
Operating Frequency: 2.4GHz
Encryption: 64-bit WEP, 128-bit WEP, WPA2-PSK, WPA-PSK, WPA-Enterprise, WPA2-Enterprise, Radius with 802.1x, WPS support
Firewall & Access Control: Firewall: NAT and SPI (Stateful Packet Inspection)
Filtering: Port, IP packet, URL Keyword, MAC address
Management: DHCP
VPN Support: IPSec Pass-Throuth
PPTP Pass-Through
L2TP Pass-Through
WAN Connection Type: Internet connection type : Automatic IP, Static IP, PPPoE(MPPE supported), PPTP, L2TP
Utilities: Device Discovery
Firware Restore
Setup Utility
Ports: 1 x RJ45 for 10/100 BaseT for WAN, 4 x RJ45 for 10/100 BaseT for WAN
Button: WPS Button, Reset Button, Power Button
LED Indicator: PWR x 1, LAN x 4, WAN x 1
Power Supply: AC Input : 110V~240V(50~60Hz)
DC Output : 12 V with max. 0.5 A current
Environmental Operating Temperature: 0 °C to 45 °C ( °F to ºF)
Storage Temperature: -20 ° to 70 ° C ( °F to °F)
Operating Humidity: 10 % to 90 % (Non-condensing)
Storage Humidity: 5 % to 90 % (Non-condensing)
Dimensions: 168 x 124 x 30 mm (LxWxH)
Weight: 210 g
Only £21.95 inc VAT.
ORDER NOW
- Seek Time: .1ms
- Slim 2.5" Design
- Lightweight: 75g
- RAID Support
ORDER NOW
Management: DHCP
PPTP Pass-Through
L2TP Pass-Through
Firware Restore
Setup Utility
Weight: 210 g
ORDER NOW
