Caporegime
- 18 Oct 2002
- block 16, cell 12
have you had the super charger dynod? if so what torque does it get, around 170-180lb/f?
Classic stuff![]()
Its the greddy. Again, cant speak directly like for like as the charger was installed when I bought it, but cant say I've noticed any dips. You can definately tell when it kicks in though so maybe its there to some degree
There is a bit of spin if its wet and your being an idiot at the lights, but I've been in far worse to be honest. And that was only really before I changed the tires to the eagles. Going through the gears you get nothing.
Also changed the exhaust to the magnaflow here:
...so sounds like a deranged wasp when the charger churps up : ) Can get a little noisy inside as they removed a lot of the sound proofing to save weight in the TRD editions, but I can live with it until I need to pass her on to her next owner. Haven't had it on a dyno yet though
Yeah, theres certainly a bit of a mystery surrounding the m's. From what I know, they were hand picked, all 1200 of them, but then uniquely modified dependant on what was available. Sounds odd, but without going into the engine completely, you cant tell whats in it. One TRD may be different than another.
For example, some were made up with TRD pistons, some werent. Some had x-section con rods, some had i-section. New, they were said to have 210 bhp but where the extra 20 came from, I have no idea
Ive read it could be down to the ECU, weight, set up.. The list goes on. Recommend them though. But whether you can get more for the money, probably. Ive just always loved the look of them as well.
Had my FL T-Sport since Sept last year, still loving it..![]()
Surprised it took you so long to pop up tbh!![]()
If anyone with a Celica T-Sport fancies something bigger I would consider doing some kind of trade with my Accord Type-S![]()
