Freezing/Lag every 30mins to 1 hour
yeah that's right,it will set the dram voltage and timings too but it wont set the cpu/vtt so manually set that
set vcore voltage response to fast aswell,then test it and see if it still freezes
im guessing your running on the bios it shipped with? id flash to the latest one as it will have stability and memory improvements,but test those settings first
In 3d mode i dont see the voltage response and in the normal mode it wont let. Me change it , but ive done everything except that now
yeah but dram voltage is only 1.5v,which seems low for 16gb
can leave it for now and see if freezing stops if its still doing it try with 1.55v dram and maybe 1.6v dram voltage later on
Its just happened again after around 2 hours 45 mins , ill whip out 8gb of ram and try re-sit stuff and see how it goes :(
can try with 1.6v dram voltage too,1.5v is ok for 8gb but 1.6v with 16gb
if it still does it I would flash to latest bios then retry
still happening with 1.6v , hopefully my pc doesnt die :( cant replace parts untill janurary ish
try with 1.65v dram voltage and 1.10v cpu/vtt if its still doing it idk what else to suggest
other than try with only 8gb of ram installed and see if it does it then
It doesn't seem to be happening as frequent now and the actual freeze/lag doesn't feel as bad , tomorrow im going to try with 8gb of ram and probably reformat , its not actual a big problem at the moment i was just wondering if something was starting to fail on me so i kow what the add to the shopping list :p
I've done every suggestion in this thread except the bios update and the fresh windows install , gonna try both of them tomorrow i guess
