I will definitely look at a 318 for my next car instead Fox, thanks. Choice this time was determined not by specs, but insurance. As a second year driver, the insurance difference between by 316 and 318 was double the price
Hopefully Year 3 of driving will be a lot better, though I'll only be 24. Year 4 of driving is when I expect insurance to be more affordable with 3 Year NCB and being 25.
If you want to lease you have to accept that financially it is likely work out a bit more expensive than buying say a 6 month / year old example of the same car.
That said, pick a budget not a car and you'll find some reasonable deals out there, what size of car do you want?
Looking at the 2.2 diesel civic EX model, I do around 17-20k a year now and my falling apart 1.7 petrol ford puma with 131k on the clock is vastly turning into a money pit
MOT is in 5 months and it will fail, cam belt over due so got 5 months to think about my next car really.
Its the older one I am after not the new one, I agree the new one looks pantsIf you want a specific car have a quick check of the deals to make sure there's nothing particularly appealing out there but then just go buy one. Consider PCP if that floats your boat.
As I mentioned before you can't really have a specific car in mind if what you want is a cheap lease.
BTW the new civic is pretty horrible inside and out, with nothing about the drive to make up for it compared with the previous car - that's coming from a happy owner of the previous model.
I'd far sooner have the likes of the new Ceed or astra coupe
Its the older one I am after not the new one, I agree the new one looks pants![]()
Ah ok, you can't generally lease used cars so go buy one I guess - make sure it's got a full history (a real full history, not some random garage stamping it every now and then), has had a recent clutch & flywheel and is wearing proper tyres... happy days.
Buys a Ferrari F40 in cash, you sir are winning at life.
