Right… Is this possible, what I’d like to do is build a small mini ITX based system that is a HTPC and capable of playing gamepad type games on a 40” telly.
Basically its to site under the telly and be used as a gaming and home cinema PC, so it needs to be relatively powerful to run games like Bioshock infinite or the new tomb raider at 1080p at a reasonable level of detail and when finished gaming use it for XBMC with catchup TV plugins.
Needs USB 3.0, HDMI 8GB memory should be enough and an SSD to boot + if possible a 2TB internal storage but could use external as USB 3.0 is quick or even eSATA could do the trick.
Case would be better in black, smaller the better.
Won’t need screen or a keyboard or mouse, just need a case and the bits to make it all work.
Possible for £500?
Possible for £500?
