So I've been tasked with completely revamping our DR system at work and if I'm honest its a bit of a mess. Currently have the following at my disposal
HEAD OFFICE
Backup Exec 11d...
LTO3 tape drive
LTO4 tape drive
COLOCATION
2x ESXi 5.0 hosts with 32GB RAM each
QNAP TS-1279U-RP (10GB RAM after RAID5)
Connected to head office via 10MB IPVPN
What I'm trying to achieve is a 3-pronged backup / high availability solution with the following
Correct me if I'm wrong, but this will allow me to have long term snapshots of the data (using tape), quick restore snapshots (via disk array) and high availability across the 10MB IPVPN at our Colo in case of major failure.
Hope all the above makes sense up to now...
The budget is £40k for this project, and as far as I can see I need to buy the following:
As you can imagine, this could be quite a challenge, as we have (in an ideal world) around 10TB of data to backup. As it stands, most things aren't backed up that should be - and that makes me worry.
Question is, does anyone else run a similar solution at their place? What disk arrays are you using? What software do you use?
I'm not after a definitive answer, or for you guys to do my job, but its good to get like-minded individual's opinions on what they have used, etc.
			HEAD OFFICE
Backup Exec 11d...
LTO3 tape drive
LTO4 tape drive
COLOCATION
- Disk-2-Disk Array for quick restore
 - Large LTO tape autoloader
 - high availability across the IPVPN link
- LTO autoloader
 - Rackmount backup server
 - Disk array with masses of cheap storage
 - Backup software (vsphere and physical) that also provides a high-availability option
 - 2x replacement ESXi hosts for the Colocation
