15, maybe 20 percent faster. Will use a lot less power also.
If I replaced everything I own with new stuff because the lastest stuff uses less electric or fuel etc it would cost be many thousands of pounds...Will use a lot less power also.
If I replaced everything I own with new stuff because it used less electric or fuel etc it would cost be many thousands of pounds...![]()
GTX 780 is a nice card (if a little pricey)
'Calls the GTX 780 pricey'
'Buys the Titan'
Are you sure about that? I thought the 780 was about on par with SLI 570's? 580's are a little quicker?
Or i could just forget about the £988 LG washing machine i just about to go down to the shop and buy and get SLI 780's instead....Mhmmmmmmmm..Now SLI 780's on the other handJust need to go sell some body parts or re-mortgage the house....
Lol,possibly.
Well there was thread a few days ago about SLI 580's vs a 780GTX and someone was going on about how a 680 with a small overlock is the same as SLI 480's. SLI 580 isn't going to be hugely better than SLI 480's so I figured a 780 would probably beat them but a bit.
Just had a look at the anandtech bench comparisons and I would say a GTX 780 would probably be about equeal to SLI 580's maybe 5-10% faster.
I looked at the hotpoint aquarius machines ,but the door opens the wrong way for where my machine goes...1K on a washing machine?? My perfectly good hotpoint aquarius was only £300 and does the job great. Enough money left for a 780![]()
