If this graphic is correct, shouldn't SR give 2500k levels of IPC performance?
Oh good, only a gen behind now then
Oh good, only a gen behind now then![]()
It'll be an annoying wait till SR.
The one hope with SR is that it forces Intel to make mainstream hex cores.
2 gens behind by the time you can actually buy SR..
..still, the gap won't be as big when it was Derpdozer vs 2500k![]()
Almost closer to three, as we'll be edging towards Haswells successor![]()
Not quite but close enough, yes.
Q1 2014, yes 'IF' the IPC is up 30% and running @ 4Ghz it will be like a 2500K running at 3.7Ghz and twice the number of cores.
If its on the shelf for £170 - ~£200 the £450 Intel 6 Core will look silly and completely unjustified, it may actually come down to a level where more people can afford it.
Fingers crossed.
Not that I believe AMD will price it that cheap, they thought they were onto a winner with the FX8150 and priced it at 250 quid.
Don't know really.
Think SR will be closer to lynfield IPC, don't think that whole 30% will be exactly what we think it is.
Even still, it'll be a very good CPU, just hope it comes out soon.
We're all of course assuming that 30% figure means IPC, it's probably a specific scenario, and something else.
How does Lynfield compare to Bloomfield? as Bloomfield seems to have a higher IPC than a lot of people (including myself) thought.
http://www.overclock.net/t/1396202/...for-my-amd-radeon-7950-boost/20#post_20085624
Lynfield is to Bloomfield what Sandybridge is to SB-E.
