Corsair 600T & 230MM Front Intake
No on the front pro sticks out just around half inch to much and door does not go on plus you have tsame with roof
You also have to remove the the HDD cage
Have you tried? So the side panel door on the 600t won't close with the 230mm fan attached to the front?
Spectre yes the extra holes it provide overhang the chassis
Sorry for long delay I'm in Ibiza
Its also to thick for the top inside and out
Only place it works is drill holes on side mesh put it on there that's what I did
I now have 3 specs that I can't use
