** NZXT Phantom 530 Full Tower Chassis - Available for Pre Order at OcUK **
  • Thread starter Thread starter rjk
  • Start date Start date
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
Overclockers UK are delighted to announce the launch of the next generation NZXT Phantom Chassis.
The Phantom 530 Full Tower Chassis brings unique design innovations to the gaming market. The modular hard drive cage design allows the end user to truly customise the layout of the system without sacrificing airflow, cable management potential or watercooling support.
The Phantom 530 is an evolution of the original in every respect.
The original Phantom set the standard for unique case design and the 530 carries this tradition onwards.
Featuring new cutting edge design features integrated into a comprehensively overhauled chassis structure, a high end gaming PC is well at home within the Phantom 530
Key Features
Up to 34 mm cable management space
8 expansion slots
235mm wide
Kraken X40 / X60 support
Modular hard drive cages
Discrete SSD mount behind motherboard tray
Steel latches
Single channel, 30W fan controller with integrated fan hub
Fully filtered intakes
20 mm cable management space
7 expansion slots
220mm wide
Case Specs
• Dimensions (WxHxD): 235mm x 572mm x 543mm
• Materials: Steel, Plastic
• Total Weight: 10.5 kg
• Motherboard Support: ITX, Micro-ATX, ATX, EATX (322x272mm)
• External Connections: 1 x Audio / Mic, 2 x USB 3.0
Bays and Expansion
• External 5.25”: 3
• Internal 3.5”: 6
• Internal 2.5”: 1+6
• Expansion Slots: 8
Cooling
• Front: 2x140mm/ 120mm or 1x200mm, (1 x 200mm included)
• Rear: 1x140mm (included) / 120mm
• Bottom: 2x120mm
• Side: 1x140mm
• Top: 2x200mm/ 140mm or 3x120mm
• Interior: 1x120mm/140mm
Clearance
• CPU Cooler: 282mm (With Pivot Fan)
• VGA Card: 310mm (With Cage)/ 444mm (Without Cage)
• Cable Management: 26mm (Lowest Point)/ 34mm (Highest Point)
Pre order yours now!
NZXT Phantom 530 Full Tower Gaming Case - White @ £104.99 inc VAT
Only £104.99 inc VAT.
ORDER NOW
NZXT Phantom 530 Full Tower Gaming Case - Black @ £104.99 inc VAT
ORDER NOW
NZXT Phantom 530 Full Tower Gaming Case - Red @ £104.99 inc VAT
ORDER NOW
Take a look through our fantastic gallery for some detailed shots of the Phantom 530:
I love white cases, mine is white with blue LED's, the problem is... there is lack of white monitors available on the market.
Great case :)
It's the perfect upgrade for someone with the original Phantom. Similar dimensions with massively improved watercooling support.
This case should have been around when star wars was on at the Pictures i am sure the storm troopers would have brought it then.
Up to 34 mm cable management space or 20 mm cable management space Which is it ?
The mobo tray is a bit curved near the grommets.
This looks like a very nice case, but how is it 220mm wide and 235mm at the the same time. Also does it has 7or 8 expansion slots? (i can count but it says both.) ;)
Thanks, and can you possibly give me information on what a single channel 30w fan controller actually is/does ? For example I'll have the 200mm fan up front, 140mm @ back, 2x fans on my rad in the top (Probably controlled by mobo bios to 1200rpm) and a 120mm blowing to the GPU. The idea of having a button to ramp things up and down seems great but can I accurately set speeds via the in-built fan controller? very confused about that sort of thing
