I'm not sure what you are trying to show with those images, especially since the exif data isn't viewable (I think imgur stripped it). The phenomena is well known and widely reported by multiple independent experts.
Looks like you kept the shutter speed constant and reduced aperture and thus reduced exposure as expected, that isn't being debated. What happens with ultra fast lenses on digital sensors is that your progressively loose more and more light relative to what is expected from the physical aperture. Therefore, f/1.2 will capture more light than f/1.4, and f/1.4 more than 1.8, but much less than expected from theory.
To compensate cameras secretly increase the ISO without reporting this, even in RAW files, so you wont immediately see this decrease. The real penalty here is that at HIGH ISO you might be pushing the sensor gain an extra 0.5 stops which would add highly visible noise, but at base ISO you may not care too much which is kind of irrelevant as for the purpose of fast glass to capture more light if you are shooting at ISO 100 then you might as well just bump to ISO 200/400 etc.
By just eyeballing your photos it is very hard to spot the difference between in exposure between your f/1.2 or f/1.4 photos, supporting the notion that at f/1.2 you are not capturing significantly more light than at f/1.4 and even if there is a significant difference you have not accounted for the camera increasing the ISO secretly to compensate. Your photos are too small to see if the noise has been increased by the camera raising the sensor gain.
You may think that raising the ISO secretly if not visible at base ISO is entirely harmless, I tend to agree, but if you consider the fact that in this line f though all camera could just secretly use ISO 400 instead of 100 as base ISO giving an instant 2 stop gain to all lenses used and making slow f/4.0 zooms behave like a fast f/2.0 zoom. Clearly we can all raise the ISO to 400 with little concern these days but there is a change in the sensor performance in doing so, most observable in the shadows. You wouldn't want to buy a lens advertised as 105mm f/2.0 when it was actually only f/4.0 and tricked the camera into increasing the ISO 2 stops.
What does remain faithful to the designated aperture is the depth of focus at f/1.2 vs f/1.4 even if you don't see all the theoretical gains in light gathering.
 You can do that right?
