Hi guys - simple question, do you think I can get away with running the following system on a picopsu 160xt (160w, 200w peak).
Q6600 G0 (95w tdp) - Undervolted by 0.1v (the max the mobo allows) and possibly underclocked to around 2ghz
Zotac GF9300-I-E
2 x 2GB DDR2 800mhz
Corsair H70 with 2 scythe fans
1 x low speed (1000rpm) side exhaust fan
Intel X25-m G2 80GB SSD
PCI-e 4x Esata expansion card
I will be using the integrated graphics so no dedicated GPU - hdds will be connected via separately powered esata external enclosure/s.
Do you think I will get away with it?
Thanks in advance
Zotac GF9300-I-E
2 x 2GB DDR2 800mhz
Thanks in advance
I think you'd get away with it at stock
