Wait till the next generation of GPU's come out.
Nothing really worth upgrading to at the moment, from SLI 470 under water.
Next gen is here for Nvidia. Just AMD hasn't done anything yet?
The 700/600 series, Titan and the HD7xx0 are all the same generation, HD8xx0 and GTX8xx are the next gen.
I'm looking for a single card. Will having only PCIe (gen 1) on the motherboard be a limiting factor on bandwidth/performance?
My mistake I thought it had PCIe 1.0.... Must have read the manual wrong. So it would be OK to run any of the latest graphics cards then?
[WU-TANG]GZA;24440595 said:Yes absolutely fine. I am running on X58 too with a 7950.
You haven't said how much you would be willing to spend.
