For my 600T. Can anyone recommend any?
I'd like the fan combo to be blue/black. Maybe with a blue led, though i will consider ledless fans. They would need to match well. I'd be looking for 1x200mm and 1 or maybe 2x120mm fans. I'd have the 200mm at the front of my case and 1x120mm in the 5.25 drive bays, held in either by string or i would use stick tabs to hold it in place. I would then have 1x120mm fan at the rear. I have a fan controller that i would connect the fans to.
I currently have some Bitfenix Spectre Pro which are decent. The front 200mm spectre pro has high airflow but the front grill/filter on the 600t seems to restrict most of its airflow. So much so that even the stock 600t fan feels like it moves as much air next to the filter. Maybe because its a higher rpm, i don't know. The 120mm spectre pro leds feel like they move nothing though. They're rated for 50cfm plus but it doesn't feel like that. I have 1850GT's at 58cfn and they feel more like 75+cfn.
