Over the past couple of days I've seen huge jumps in my CPU temps and more than I'd expect from just hotter weather. I'm wondering if the pump on my H100i is on the fritz somehow (3 months old) or if my OC has just gone unstable (also 3 months old).
Background:
I picked up a new GTX 670 for a SLI setup, first ever SLI and was running a benchmark on the new card on its own to see if it ran faster than the one I had (same model, no OC on the GPU). I realised the H100i was running like a hairdrier at the end. I have a 3770k CPU OCed to 4.5 Ghz on a 1.2 vcore using MSI Z77 Mpower. It's not a fixed OC but a dynamic or boost or whatever you want to call it.
Symptoms:
I used to get great idle temps of between 26 to 28 degrees, maybe hitting low 30s with a light load. Gaming for a few hours would maybe see temps rise to Mid forties, 50 at the very highest. Prime95 test over 10 hours when I first OCed saw a peak temp of 63 on the highest core, average of around 55-57.
Now, idle temp is high 30s to mid 40s. A task like installing new nvidia drivers saw temps hitting 60+ degrees, temps I used to get on prime95 burn in. Getting WHEA errors at these temps.
I've tried reinstalling the corsair link software, deleting all profiles, uninstalling, reinstalling etc. Tried all connections, new USB header for the cooler, new fan headerson the board and on the pump etc. Uninstalled the radiator and checked for dust etc. I've reseated the cooler with no improvement, maybe marginally worse, checked the backplate is tight. Also tried swapping in the old GPU just in case that was somehow the cause.
A few weeks back, I got a similar problem during gaming when I was installing mods. What seemed to fix it then was either reinstalling/repairing the link software and/or removing the radiator and blowing dust out even though there wasn't really much. Not sure which, it just improved after I did both but neither have worked this time.
Reason I'm wondering if the pump is on the fritz is because it almost seems as if coolant isn't reaching the radiator properly, even though one hose appears warm, the other cool and corsair software saying the fan is working. I can't feel any vibration from the pump. I've found that fan speed basically doesn't seem to affect CPU temps at all. At 400rpm or 2200rpm, CPU temp will stay roughly the same. H100i temp readings always used to be pretty static even when the CPU was under load. They'd stay around 25-28 degrees, maybe nudging over 30 after a period of time at load. Now the H100i temp shoots up straight away into the 30s, even 40s straight out of boot, which is what causes the fans to go crazy. Despite these high temps, the actual radiator seems cool to the touch.
I was hoping to avoid it but my next step was to possibly disable my OC and see if things normalise then. Another option was to salvage my Hyper 212 from my other PC and see if that can cope with the temps any better, logic being if a Hyper 212 can cope better than a h100i, the h100i is screwy. If not, maybe it is the OC.
I welcome any suggestions.
Background:
Symptoms:
