Electric conductivity of oil?
Why used oil? It will contain contaminants and be very dark in colour. New oil may be better.
It would work with new oil (for a while anyway), but old used engine car oil is loaded with carbon and acidic byproducts from combustion so I suspect conductivity is rather higher.
I am not sure what the electrical properties of motor oil are off hand are but I would not assume it is a particularly good insulator. Motor oil contains many additives which are metallic compounds which may not be particularly good for compact electronic circuitry.
While "Simple"electrical devices (Solenoids etc) are OK exposed to oil (Auto box solenoids etc) vehicle ECU's can be damaged by oil getting into them. (It is not uncommon! Oil creeps along the wiring loom and gets into the boxes)
yes it more than likely would work.... should you use used car oil? nope.jpg :p
as said, you can use mineral oil (look at vids on youtube of pcs submerged in fish tanks :D ), but car oil...not too sure of the additives...let alone all the gunk/particulate that would be in the used stuff xD
Mineral oil is your best bet.
We use it in a variety of equipment at work as insulation. The voltages I work with require the oil to insulate over a 2.5mm gap at 30kv the oil often passes 60kv average which is the max the machine goes to.
An oil cooled pc has been done before, not engine oil though.
Used engine oil will have very small pieces of metal in it from the engine which would obviously be conductive.
What about submerging a heatsink in oil rather than the whole pc?
I wonder if the OP is not actually thinking of putting used oil in a PC, but is thinking of putting a small PC in oil in a car? Like a Raspberry Pi in an oil reservoir?
No idea why though.
In which case the conductivity of the oil would be a pretty minor problem compared to the temperature of the oil.
Not so much the oil temperature but just heat, oil is really only exceptionally hot around the piston crown, skirt and bore, oil is cooler in the head for example but a lot of heat is generated there in itself.
Electronics can cope with several hundred degrees, they just need to be industrially insulated.
