- 29 Dec 2009
Not a troll thread I promise.
Would a PC work if it were submerged in used car oil?
It would work with new oil (for a while anyway), but old used engine car oil is loaded with carbon and acidic byproducts from combustion so I suspect conductivity is rather higher.
), but car oil...not too sure of the additives...let alone all the gunk/particulate that would be in the used stuff xDSurely if even it had the tiniest bit of conductivity, it wouldn't work as the gaps on circuit boards are minute?
I suspect this is an electronic device going into the crankcase, or somewhere in the oil train, not a PC project.
In which case the conductivity of the oil would be a pretty minor problem compared to the temperature of the oil.
