- 29 Dec 2004
- Shepley
[Damien];24415983 said:Yeah it's the fizik performance stuff I've got. The problem is that apart from it being super thick, it's got a very defined pattern on it. It's got a flattish perforated bit about a third of the way across, then a raised bump bit, then a flat fizik logoed bit. That means you don't really have much leeway to vary the overlap. Also because of the thickness it likes to go baggy on the top edge as you tighten the bottom edge.
Don't be afraid to pull it quite tight as you're wrapping, that tends to make life easier.
mine for e.g. switch properly all the way bar 3rd ring where i have to "force it" on in a way.. annoys me but i kinda got used to it..
