- 28 Oct 2011
It's normal, replacement will likely have the same issue.
Absolute nonsense.
Absolute nonsense.
the sound mine makesthis is in game it was little louder last night seems less now tho
sorry about the video size lol
)I've got 2 7950s with no coil whine. My system's completely watercooled.
Get over yourself, seriously.
BloodZeed, i don't hear any noise other than fan noise
This is what my card sounded like and got accepted for RMA, not tested my RMA replacement though been having other cards on my test bench
My other three 7970s have been whine free though![]()
That's pretty bad coil whine on your card, sounds like crackling!
The noise in the video he posted does show coil whine, quieter than normal compared to other 7970 cards I've seen. It actually sounds a bit like your background noise before valley is loaded :/
If I was him I wouldn't risk it as a replacement could be worse.
Yeah that card was very bad, only took two weeks for the RMA with HIS. Bloods video doesn't sound like anything terrible, just fans imho...
That sounds funny, whine on an old PSU![]()
Are you sure its coming from the psu? Sounds like graphics card whine to me, especially the way it gets higher pitched at the close menu (due to really high fps) If it was from the psu it would mask the graphics card whine so doesn't prove anything heheheh
He said it stops after closing a game though so its more likely coil whine. I know what you mean about the fans though, I've heard some that have a buzz to them.
Did you deal with HIS directly? Where did you have to send the card?
That video shows coil whine immediately after heaven startsAre you sure its coming from the psu? Sounds like graphics card whine to me, especially the way it gets higher pitched at the close menu (due to really high fps) If it was from the psu it would mask the graphics card whine so doesn't prove anything heheheh
Edit - I should look at the video instead of just listening, does seem to be coming from the psu area but could still be masking the noise from the gpu.
Defo the PSU mate, that's why i started to go over the GPU at the start of the video! to show it wasn't that.
I have that exact GPU on my bench atm, can fire up heaven just to show you if you wish
I've had more PSUs that coil whine than GPUs. My replacement 1200i is whines, i only really notice because its on an open test bench so when it's in my case on the floor it wont bother me too much.
p
My background noise were the fans on that GPU iirc, pretty sure that video was taken after i setup my chiller loop (no fans, no noise)
Edit: Pretty sure that is a video on youtube of a whineless GPU....underload? amirite?
Quote:
Originally Posted by Darujhistan
Absolute nonsense.
Once I come across a modern graphics card without coil whine then I'll agree with you. Coil whine most certainly is normal (very rarely it can be really bad though)
It's not normal, its rare. I have never had a coil whining card.
Coil whine is not supposed to be normal. Its supposed to be a problem. At any rate my card didn't have any.
It is normal. If you contact any graphics card company they will tell you that it is. A very odd time though a card can have extremely bad coil whine. Sometimes some people only notice it when its really bad, and other times people notice it when its quieter. It all depends if your looking out for it and ambient noise/noise from other fans.
This thread is an example of this. The op posted a video showing his coil whine and another user said he doesn't hear anything except fans. But OP can hear it, otherwise would not have made this thread or posted the video. It's all subjective, but coil whine is normal. Coils vibrate when the card is drawing a lot of power, there's no avoiding it.
Its a common occurrence but its still a defect and basically saying there is no threshold on how many you should put up with.Page 13 of the PSP manual puts it this way: "Red, blue, or green spots (bright spots) or black spots (dark spots) may appear in certain locations on the LCD screen. The appearance of such spots is a normal occurrence associated with LCD screens and not a sign of malfunction. LCD screens are made using highly precise technology. However, a very small number of dark pixels or continuously lit pixels exist on each screen."
coil whine that you have to be abnormally close to before it could be heard.
Again this is subjective. I'm using a 7770 right now which you guessed it... has coil whine. It's much quieter than some other cards I've used since its lower powered but I can still hear it very easily, and I don't need to get abnormally close to it. I can hear it because my system is quiet. I have a passive power supply, the graphics card is passively cooled and my case fans run at very low rpm.
When someone makes a thread about coil whine, you can't assume its the extremely loud kind that definitely needs replacing.
As for OPs video, you won't find many 7970's with coil whine that quiet. If he listened to people saying 'coil whines not normal definitely rma' etc then he might have returned it and ended up with a worse card as loud coil whine is extremely common on 7970's.
How many RMA's do you think stores like ocuk and graphics cards manufacturers have to deal with due to this 'issue'? There is literally countless complaints about it. If it was possible to make cards without coil whine then that's how they'd be made, imagine how much money they'd save on returns.
Graphics cards have always been like this, its not a fault, just how they operate
http://www.rage3d.com/board/showthread.php?t=33824347
As far as I'm concerned people either
A - can't hear it due to other noises
B - hear it but put up with it, after all it normally only happens when gaming.
C - return the card, end up with another one which whines, enter an endless cycle of disappointment, finally accept it.
D - genuinely get an extremely loud one, returned and replacement is fine (albeit just with less coil whine which may or may not be inaudible to that user)
I've yet to see a single graphics card that is whine free, and I've been through so many its not even funny.
