Hey guys, I've been planning my new build, and got around to case fans,
My question is can you trust the numbers that are posted for (as far as im aware these are the important ones to look at)
- Max airflow
- Max static air pressure
- Noise level
as reading reviews for some fans seem to give different results.
so can you trust the information that's listed on the product pages???
also
I'm looking for 3x 140mm for the case and 2x(maybe 4) 120mm for a Corsair H100i, if any one would like to recommend some
cooling is the number one factor then noise. ideally i'm looking to leave them on low on all but the hottest days
- Max airflow
- Noise level
also
