I'm running 2 7970 and have no problems at all. Fans never go above 40% and is very quiet even on a small overclock.
Nice, which 7970's and what clocks speeds?
you telling others what they should accept it at a particular level
You're the one saying its unacceptable if it can be heard at distance. I'm saying its subjective. Whats unacceptable to you may be normal to others (i.e me!)
The point is you telling others what they should accept it at a particular level and you not being able to accept that many people don't have that level of coil whine and they need to be unrealistically close to hear it and the fact you continually take a figure of speech out of context and apply it literally.
My msi 7970 OC has very mild coil whine when i pump a lot of voltage through it. Otherwise its virtually unnoticeable and not in any way annoying.
I've now had three HIS 7950 Ice-Q's (soon to be 4) and none of them have had even the slightest bit of coil whine.
Even my case has coil whine.
780's have coil whine too
starts at 0.55
Which Ice-q version do you have? The blower or dual fan.
this for all cards?
Blower, but to be honest its so quiet it feels an insult to call it a blower.
If I buy a 7950 that's the one I'll get.
ps. won't blame you if it whines![]()
