Build critique - PSU especially
9 Jun 2004
I'm looking to upgrade from the system in my sig. Here's where I am now:-
(I'll be water cooling, everything is sorted on that front except the CPU block, as below). I'll be overclocking the 7950 and 4770 :)
No need for case or other peripherals.
The build below has a Seasonic PSU, mainly because I have one now, and it's been rock solid. Is this really worth it, or should I just save some money and grab an XFX, Corsair, or something?
Any other suggestions welcome too.
YOUR BASKET
1 x Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - Retail with FREE Grid 2 PC Game £269.99
1 x MSI HD 7950 OC BE 3072MB GDDR5 PCI-Express Graphics Card (R7950-3GD5/OC BE G) £217.99
1 x Gigabyte Z87X-UD3H Intel Z87 (Socket 1150) DDR3 ATX Motherboard £154.99
1 x Seasonic X-Series 750w '80 Plus Gold' Modular Power Supply £129.95
1 x TeamGroup Xtreem LV 16GB (2x8GB) DDR3 PC3-17000C11 2133MHz Dual Channel Memory Kit (TXD316G2133HC11DC01) £99.95
1 x EK Water Blocks EK-Supremacy Clean CSQ £51.95
1 x Arctic Silver 5 Thermal Compound (3.5g) £8.99
1 x Akasa AK-TT12-80 Thermal Adhesive Tape £2.99
Total : £936.79 (includes shipping : FREE).
Looks like a solid build, as snips said you could downgrade to a 650w PSU if you want to save a bit, however if you plan on crossfiring the 7950 in the future a 750w or higher would be best :)
I'd go for the new revision of the MSI card...
Ahh, is the one I have the older rev of
http://www.overclockers.co.uk/showproduct.php?prodid=GX-190-MS&groupid=701&catid=56&subcat=1673
I thought it was just a separate model with less fancy cooling (since I'll be taking the stock cooler off, it doesn't matter to me).
Re: PSU, thanks for the comments. I might plump for something like
http://www.overclockers.co.uk/showproduct.php?prodid=CA-013-XF&groupid=701&catid=123&subcat=2597
as a compromise.
Build looks good. What will the PC be used for?
Basically gaming and all sorts of development (I like to play with multi-core stuff when coding, and plan to keep this for as long as I've kept the trusty q6600 system, hence the i7 -- plus, compile times are better).
