I don't see why anyone would go AMD right now apart from loyalty tbh, I reckon those 8 slow cores will get thread limited in games in the near future if they aren't already in some games
my 4670k @ 4ghz is already pulling 73% cpu usage on the most used core in the most cpu intensive game I own.
surely the awful single core performance of the amd chips will be a huge issue very fast for gaming.
when in games that multicore well you're hitting 73% cpu usage and 50% on every other core you knows it's going to make an 8350 keel over because that 73% cpu usage clearly cant be split between threads any better than it already is.
Cinebench 11.5 - Single Threaded
Score in CBMarks - Higher is Better
fx 8350 = 1.1
haswell 4670k = 1.7
thats a huge difference in core for core performance
Agreed if you are only or mainly playing games that rely on the single core performance. There are plenty of benchmarks that show the 8350 on a par or slightly better than the 3570 for multicore game engines.
I am not going down the fanboy alley. Both are very good gaming processors with the caveat of lower single core performance on the piledriver.
The 8350 is far better than the 1090T which I had previously in the same machine. It maxes the (admittedly midrange) overclocked HD6950 at 99-100% GPU usage at 40-50fps in ARMA2. Very playable. And without the CPU bottlenecking.
For BF3 it is at least as good as the 3570 and close to the 3770. Normal resolutions.
I quote the last generation Intel as there is more data available.
My 8350 will overclock 25% above stock and game at 5GHz. For encoding and rendering tasks it is similar.
Prime or IBT will fall over above 4.7-4.8Ghz on eight threads but I have not yet seen many posted prime runs on Haswell to show stability when overclocking.
It is largely down to personal preference or pricing. Both are good gaming platforms IMHO.
you're also forgetting it has higher clock/more cache = More core for core performance.
