*** The Official Samsung Galaxy S4 Thread ***
Looking at the screenshots of domination theme, it does look pretty good (although a black and white version would have been nice too like BlackOut X theme).
So the way I'm looking at this is as follows:
- Use Wanam
- Use Domination Theme
- Use Nova Launcher, minimilistic text, Icon Themer, Missed It!, RoundR, Widget Locker, XPosed Installer Framework (for Icon Themer)
- Install an Icon Pack
- Install CM10.1 apks (SMS, Dialer, Contacts etc)
- Change font using Rom Toolbox Pro
Job Done?!
The only thing i will be missing is the BlackOut X theme but i guess i can live without that for the time being...
Change the font to what? JB Dom will give you the stock font throughout AFAIK.
Sergio....my fav font
Also, i notice that Domination has a chrome theme option too which is black and greys. Love it! Is this something you install over once you have Dom installed.
I'd guess it's something you pick from the theme menu if its in there like you get in CM10.1, otherwise yeah it'll be a flash like JB dom itself. No idea tbh as JB dom gets it pretty close to perfect for me.
Nexus you saying using Omega will make the camera and other things worse? Everything looks in order here, not that I ha en played around with much.
No he's saying that ASOP style ROMs will have worse cameras due to not having the samsung camera software, if you use a samsung based ROM like Omega or Wannamlite then you'll be fine.
So....
Use Odin to install a pre-rooted ROM (like suggested and link provided above).
This should root my phone.
Then install a custom recovery (CWD).
Flash Wanam Rom
Flash JB Dom theme
Install CM apk's
Ye?!
I'm guessing there is only one version of Wanam and JB Dom that works on all S4's rather than having versions for into, us ect depending on handset?
There are two Wanamlite roms, one for the i9500 and the one for i9505. Be careful!
There is no need to install a pre-rooted rom, just flash CF-root and recovery, and then flash wanam/omega and whatever else you want extra, like JB Domination/CM APK's
1) http://forum.xda-developers.com/showthread.php?t=2219803 - Flash this via Odin as PDA (See post #2)
2) Flash a custom recovery such as CWM or TWRP - Latest CWM can be found here: http://forum.xda-developers.com/showthread.php?t=2279579
3) Copy over a rom such as Wanamlite or Omega to your external SD card
Wanamlite: http://forum.xda-developers.com/showthread.php?t=2283194
Omega: http://forum.xda-developers.com/showthread.php?t=2253528
4) Reboot phone into recovery and flash the rom
5) If you're already on stock rom there's no need to factory wipe data, no harm in wiping cache/dalvik though, but not compulsory
6) Enjoy your new rom :)
A legend and a scholar!
That seems easy enough...... Touch wood!
Do you use the GApps package from CM to install/flash the CM apk's?
Flash JB Dom straight after flashing Rom?
So there is no Gapps package to install? Just the Rom and the theme?
@ Stoosh & Kona786:
My Spigen Slim Armor that I told you guys about a couple of weeks ago just arrived today, will get some pics up shortly.
Edit: Posted the pics on the accessories thread.
Is the power button on your guys case very stiff? I cant see any gaps or anything stoosh but to be honest I dont really like the case overall, the back of it just attracts fingerprints so badly it's unreal! It was worth it for the price, even though it will probably idle in the cupboard!
I haven't used CM/AOSP on my S4 but I'm guessing it's the same as it was when I had my S3/N2, there's a seperate gapps zip file that you flash after installing the rom yeah.
I flashed JB Dom after installing Wanam (I let the phone boot up once first before flashing JB Dom).
With Wanamlite/Omega there are no gapps package to install. :)
When does the Google experience version come out? And if I purchased a normal s4 will we be able to just port that on ?
They're out on June 26. I think it will just be a process of flashing a ROM just like you would with any other, so yeah you'll be able to flash it even with a standard S4 :)
Anyone know how we check the camera firmware version?
Dial *#34971539#
Cheers bud.
Mine's
Is this the latest?
What is everyone running?
