Whether it is lying on the table, sitting in the office, at the airport, or on the train, can let sleep whenever and wherever possible. It looks like a large hood, almost completely covering the head and neck, only his nose and mouth breathing.It also has two side holes, a user can extend the hand, completely isolated from the external interference, resulting in the privacy and comfort in small spaces have a nap. Need an afternoon nap? There's no better way to find comfort,silence and darkness than with an Ostrich Pillow on your head. Experience sleep so deep, it will even drown out the angry cries of your boss! The Ostrich Pillow is a new portable device that its inventors say will "enable power naps anytime, anywhere" including in airport lounges and on planes. Design: Stuffed with synthetic material, the distinctive-looking pillow has a hole in which to put your head, and a mouth hole designed to allow its wearer to breathe easily. It also has two side holes where you can store your hands if napping at a table in a library, for example.
