Narrowed my search 2 graphics card, which one?
Good stuff! Let us know which one you choose :)
Seriously...they're both about the same performance wise with one or the other edging it in certain titles.
on another note ive never heard of KFA2?? reliable or not? might just spend 10 more pounds for the MSI one ?? that is if i do go for the gtx 670 and not the 7950
http://www.techspot.com/review/603-best-graphics-cards/page4.html
the gtx 670 beat the 7950 in every single game. Im a fan of amd stuff and it seems like everyone in here loves 7950 from previous advice and im still not sure lol... on paper it seems 670 but from peoples experience 7950? in terms of overclocking are both the same, easy to do / monitor and etc?
Edit-
Look again, the standard 7950 is a stupidly low clocked GPU, about 800Mhz I think, its about 20% less than where is should be and 40% less than it can do day in day out.
If you look the little higher clocked 7950 BE (925Mhz) sits above the GTX 670 in most things.
Both good GPU's, nothing really between them, as arc@css said, Flip a coin.
The one that Kaap linked is very quiet, and iirc, it isn't voltage locked. That means that you're not restricted when it comes to overclocking.
looks like it might be that 7950 kaapstad linked over the gtx 670, anyone else opinion ?? Also will there be any new graphics card within 2 weeks period? i will most likely buy this by next week and there is always deals here i think... or any good graphics card deals im unaware of? around the 250 margin
The GTX760 is due to be launched June 25th apparently...should be around GTX670 performance so maybe you should look at that before you buy?
pipson, i edit my post, you might want to see it :)
I do think its one or the other. but I do agree with the cooler argument.
Expected or estimated price?
and performance in comparison to 7950 cause the above posts have convinced me to get that and i wouldnt mind waiting till the 25th
