Gigabyte GeForce GTX 670 8 Pin?
17 Oct 2002
Leeds
Hi there
I have a Corsair HX620 Modular PSU. As far as I know it only has 6 pin power connectors for the GPU. This card needs a 6 pin and 8 pin. If I wanted to buy this card how would I power it with my current PSU?
Thanks
Hi there
Thanks
Take a closer look at your 6 pin connector leads as most do have 6+2 connectors, you'll more than likely find a 2 pin connector which is just folded back on the same lead, if this is the case then just side it with your 6 pin.
Older models did indeed only have six pin but worth a check before using adapters.
http://www.hardwaresecrets.com/article/371
