- 7 Aug 2011
First off I don't know a lot about Metal Halide. I bought a second hand unit for my fish tank and a new 14k 150W arcadia bulb. When i turn the unit on the bulb just arcs and doesn't light up. I have no idea if it is a problem with the bulb or the unit? The bulb arrived with a yellowish gunk on the inside of the main chamber. Is that normal? Did i just buy the wrong type of bulb for the unit? Or is it a problem with the ballast or ignitor.
Any help would be greatly appreciated.
, just read OP post again, missed the bit about yellow gunk,No not normal, BUT it could be a faulty ballast, causing lamp to blow,or failing to light up.
