Gaming Rig - Bottleneck?
1 Apr 2013
newbie question. you may have seen me before, i've decided to up my budget.. by a lot! here are my new specs..
CPU: i7 3770k (gonna overclock to a safe 4.2)
GPU: Asus GTX 680 2GB
CPU Cooler: Corsair H100i
Mobo: ASRock Extreme4 z77 Motherboard
PSU: OCZ 850W PSU 80+ Gold
RAM: 8GB Corsair Vengeance
Case: Zalman Z11 High Performance (all fan slots are going to be used)
Will any of this bottleneck?
you suggest the 4670K snips but that CPU isn't in the basket ;) I'm pretty certain the H100 doesn't fit the zalman chassis either.
my rig is down for maintenance so someone else will have to step in and spec
call it what you want but the chassis doesn't fit 240mm rads not many budget cases do
He's right!!
The top of the motherboard needs space for the Rad, if it's not there, you're not going to get it in. The fans space is not all that is required.
Check out the Corsair range - 200/300R
