Sell the poorly chosen gpu. Buy a normal gpu. Buy two more systems. The load per system is thus halved.
Nothing else will make financial sense. Don't buy a 3k+ dual socket intel system in order to keep using a 500 quid card, that's throwing good money after bad.
Edit: 6 core sb-e may work, but doesn't exactly lend itself to future expansion
@ JonJ678 - What makes you say, "poorly chosen gpu"? I'm not buying anything yet, just considering options. Adding more computers adds to rack usage (all rack mounted), power consumption (UPS load), network ports, etc. etc. so whilst its a consideration, its not the preferred choice as there are hidden costs with that option. Also the 3770's are working at 60% load under normal conditions with peaks up to 90% in certain conditions with 36 streams loaded on the workspace, so my consideration and discussion here is already looking forward to the future, I stated in the first post that I'm NOT looking for a FIX.
@ joeyjojo - I read that article, thanks for the link, I would hazard an educated guess that the Calgary client's budget is a factor of x10 larger than our client, who is just stepping out of the Analogue world and into the Digital. My guess is that either that they scaled the wall with more hardware to drive it, perhaps 2:1 ratio on screens to workstation, or using server grade Xeon dual socket subsystem for more decoding power, or yet another option, custom engineered hardware with dedicated hardware decoders, these by the way are in the range of 20-40K per box and boast multiple Xilinx FPGA processors with far more logic gates and processing power than your commercial grade CPU, yes even a Xeon. One other clear difference between the two systems is that the Calgary client's system is based on 1.3MP/720p cameras, our client's camera system is 4CIF/D1 resolution, so there is a distinct difference in in pixels between the two systems, that's why I am able to decode 36 streams from the one workstation.
There is however something that was highlighted in the article that I will investigate when I return to site, and that is the network side because our system is also set to multicast, so there may be a hidden issue there as well.
@ IceWind - I'm not convinced an AMD solution will work. AMD chips, even with extra cores consistently perform lower than Intel chips with half the number of cores in computational related benchmarks, so adding extra cores only works if the two were even in computational performance to start with.
best regards from Doha, Qatar. Its bloody hot here, 44C during the day
Hum
