Check my system build.
Thanks for the replies, I will have a think about them.
No worries fella :)
In my spec.....The 770 is a "Super Duper" 680 basically. The SSD is faster for less cash, the B grade HDD is there as an option to save some cash too. RAM is also faster @2400Mhz (do you need 16GB?). The Antec case will be quieter than the Bitfenix Ghost (I'm not really too keen on it).
I can understand a CLC to "show off" if you had a windowed case but as you haven't picked one either stick with the Bequiet cooler or add the K2 Mount Doom to the basket. Oh the PSU is also Semi-modular (Snips didn't use one) which helps cable management, the 630W version is £10 more if you want the extra headroom
