I might enter this if there are still places
I took a photo of all the stickers that I saw on the board, but I guess I missed the one on the power connector. I'll see if I can get a snap of it...
Apart from this offer is there any reason you'd get this board instead of a Z87X-OC?
Without this offer they're similarly priced and I'm wondering if I'm missing something. Ready to pull the trigger on my order and want to be sure about my mobo choice!
No doubt you've already ordered, but for anyone else that's wondering:
If you have two air-cooled GPUs, the UD4H may be the more attractive board - there is a three-slot gap between the two SLI-capable PCI-e 16x slots. So, you have a clear slots worth of space between your two GPUs. On the OC board they will be jammed up against each other. Should be worth 7-10 degrees off the top GPU under load, depending on specific GPU cooler design.
