Any idea what box is in a 2003 (pre facelift) E53?
Just read codes on my friends box:
His car is entering the transmission limp-home mode. (Locks into a single gear, possibly third, I think).
E R R O R M E M O R Y R E P O R T -------------------------------------
Date: 06/08/13 14:54:47 ECU: GS20 JobStatus: OKAY Variant: GS20 -------------------------------------------------------------
RESULT: 2 errors in error memory ! -------------------------------------------------------------
55 Gear Check 5
Error frequency : 1 Logistic counter: 19
km value 187280.00 km Changing gear 0.00 0/1 Last change: Changing up 4->5 35.00 0-n Gearbox Oil Temperature 84.00 degrees C Battery Voltage 14.00 Volt
General error Sporadic error -------------------------------------------------------------
54 Gear Check 4
Error frequency : 2 Logistic counter: 3
Error occured 1. times at:
km value 187580.00 km Changing gear 0.00 0/1 Last change: Changing up 3->4 34.00 0-n Gearbox Oil Temperature 78.00 degrees C Battery Voltage 13.90 Volt
Error occured 2. times at:
km value 187580.00 km Changing gear 0.00 0/1 Last change: Changing up 3->4 34.00 0-n Gearbox Oil Temperature 81.00 degrees C Battery Voltage 13.90 Volt
General error Sporadic error =============================================================
I did have a tiny bit of air left in the system when I re-checked the next morning but nothing major at all.
