Hi there
OcUK has secured UK/European exclusive on KFA's flagship GTX 770, the LTD OC edition which features white PCB, fans, cooler etc. It looks totally awesome and ideal for anyone who is building a setup based more on a white theme:-
KFA2 GeForce GTX 770 LTD OC 2048MB GDDR5 PCI-Express Graphics Card **WHITE EDITION** @ £359.99 inc VAT
The KFA2 GTX 770 LTD OC all white edition is produced with a white PCB, two 8 pin PCI-E power connectors for a maximum TDP, Overclocked. Cooled with custom white three 90mm fans and five heat pipes leading to an aluminum fin array. The result of this is a card which is quieter and cools better, whilst at the same time can also offer great overclocking ability. Then to finish it off this card looks absolutely amazing and is very unique with its all White Design including PCB, Fans and shroud.
Feature-rich and stacked with advanced gaming technologies like NVIDIA® PhysX®, TXAA™, ShadowPlay, and much more. This gives you the performance edge you need to take on next-generation titles like Splinter Cell: Blacklist and many others. It's serious equipment for the serious gamer.
Features:-
- White PCB, White fans, White shroud for that exclusive and unique look
- 2x 8-Pin power connectors for better TDP resulting in better overclocking ability
- Tri-Fan cooling, less noise, better cooling, longer lifespan.
- Fastest GTX 770 out the box on the market with 1254MHz Boost Speed!!!
Specification:-
- Core Clock: 1202MHz (GK104)
- Core Boost Clock: 1254MHz
- Memory: 2048MB GDDR5
- Memory Clock: 7010MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 1536
- Shader Clock: 2404MHz
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 1x DisplayPort 1.2, 3x HDMI
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- 2x 8-Pin PCI-E Connectors required
- Warranty: 2 Years
Only £359.99 inc VAT.
ORDER NOW
If your in Europe our partners www.Caseking.de shall also be offering this same product shortly as well, who are based in Berlin, Germany.
Features:-
Specification:-
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 Years
ORDER NOW
