AMD 13.6 Beta 2 Benchmarks
Caporegime
12 Jul 2007
United Kingdom
AMD 13.6 Beta 2 + 13.5 Caps
i7 2700k @4.7ghz
8Gb 2133mhz Memory
2x7950 @ 1093/1563
27" DGM IPS 2560x1440p
Windows 8 64 bit
Settings Used
Battlefield 3 - Ultra Preset + x4 AA + FOV 80
Bioshock - Ultra Preset + Alternate DDOF Disabled
Dirt Showdown - Ultra Preset + x8 AA + Global illumination
Hitman Absolution - Ultra Preset + x4 AA + Global illumination
Sleeping Dogs - Extreme Preset + Extreme SSAA
Tomb Raider - Ultra Preset + x2 AA + TressFX
Results
Max fps values for Dirt Showdown, Bioshock are put at 150 to keep the graphs in perspective. Max fps for Dirt Showdown is not available in the in game benchmark, though i believe it is around 150. Bioshock max fps was 315. Not sure what happened with the low minimum on bioshock, must be a bug as it definitely doesn't go that low when running the benchmark.
More to follow...
Nice averages all round, particularly at that res. Havent played tomb raider 2 but it seems to be pretty demanding.
I suppose at high res such as 1440p the need for aa isnt as great? Never been above the giddy heights of 1920x1200 yet.
I don't normally use it in Tomb Raider when i play as i can't tell any difference with it on or off. :p
Does this improve crysis 3 as it's the only game I can't max out?
I'm going to add some more benches in due course. The problem is i lost my crysis 3 saves when i reformatted recently so i have to play single player to get up to the benchmark point again.
