Unfortunately, due to age and not enough use, the seals on the pop-up roof of my Transporter are cracked and worn. The glue sealing them to the roof is also failing and when I pop up the roof they stick to the main roof instead of the pop-up roof and essentially have to be torn off it.
I tried some silicon sealant a few days ago to try to stick them onto the pop-up roof better but made a bit of a hash of it so I intend to try that again but better, but I need to do something with the seals themselves.
I'm thinking clean the main roof where the seal joins it and coat the seals in vaseline to try to stop them sticking to the main roof and making the problem worse. Anyone have any pearls of wisdom here?
TLDR: seals worn and sticking to main roof, use vaseline to help sustain them/stop them sticking, or something else?
