cables / IT bits & bobs BAG needed
5 Jun 2005
Southampton
currently using a wash bag for all my cables, chargers, dongles and USB addon's/drives :D
i tend to travel over night once or twice a week (UK mainly) and need all my IT bits and bobs, looking for something a bit better than the current wash bag, same sort of capacity, but maybe A4 paper sized and 3" or 4" deep, so i can see what is in there....
any recommendations or ideas?
Will this do Jimlad?
It's got enough storage for cables etc and can't be seen by anyone either.
i don't want a rucksack, that would be overkill, i need the capacity of a washbag, that either opens out with compartments or ideally something the size of a A4 bit of paper and around 3 or 4 " deep
Coincidentally that's the sort of thing the guys who we had come to install our new router used - it looked as though they had every conceivable sort of network related tool between them.
Annoyingly OcUK sell laptop bags, so I can't link to the manbag site as they're technically a competitor. Have you considered a simple messenger bag, such as this; http://www.overclockers.co.uk/showproduct.php?prodid=TB-009-PV&groupid=959&catid=2434?
Get a slightly bigger washbag, the size of an A4 bit of paper and around 3 or 4 " deep.
sounds perfect, you got a link for that?
"Magnolia - 17,511 useless posts and counting"
2007 - 2013
ThinkTank Photo, who obviously specialise in camera bags, make organisers to go in the bags which sound like more or less what you seem to describe you want.
They have four different sizes and you can see through them to:
http://www.thinktankphoto.com/products/cable-management-10-v2.aspx
http://www.thinktankphoto.com/products/cable-management-20-v2.aspx
http://www.thinktankphoto.com/products/cable-management-30-v2.aspx
http://www.thinktankphoto.com/products/cable-management-50-bag.aspx
couple of them will do the job :)
