- 20 Jul 2009
- The bleak North East arm pit of Britain
Hello
Synology populated NAS built and tested in house by the OcUK Technical Team has had a price slash! The NAS has between £12inc VAT and £285inc VAT slashed off the prices!
Most of these units should come at a price pre-built lower than it is to buy the parts off the shelf here at OcUK and many other online stores so check out the range HERE and find below a couple of the best value pre-built units.
Find the whole range HERE!
Synology Diskstation DS112+ 1-Bay Gigabit Ethernet Network Attached Storage Enclosure - 4TB @ £339.95 inc VAT
2.0GHz Cpu frequency, 512MB Memory, 4TB Capacity, 2X USB 3.0, 1X eSATA, 4TB Max HDD Support, 1X Gigabit LAN, Synology DiskStation Manager
Synology DiskStation DS112+ High-Performance 1-bay All-in-1 NAS Enclosure
Key Features
107.92 MB/sec Reading, 76.66 MB/sec Writing
Features SuperSpeed USB 3.0
Hardware Encryption Engine
Complete Backup Solutions
Running on Synology DiskStation Manager (DSM)
Synology® DiskStation DS112+ offers a high-performance, and full-featured network attached storage solution that helps small and medium-sized businesses centralize backup, protect critical assets and share files quickly and efficiently. Synology protects your investment in the DS112+ with a 2-year limited warranty.
High Performance
The Synology DS112+ is designed for business users who demands high-performance for file sharing and running of office applications. The Synology DS112+ delivers an average 107.92 MB/sec reading and 76.66 MB/sec writing speeds in a Windows® environment
Coming with USB 3.0 support which offers transmission speeds of up to 5 Gbps, namely 10 times faster than USB 2.0, DS112+ takes less time for data transfer for external hard drives and consumes less power.
Peace of Mind with Data Encryption
The Synology DS112+ is equipped with an encryption engine which offloads the encryption calculation task away from the main CPU, helping to improve file transfer speeds of the DiskStation.
Data protection is an important matter for businesses of all sizes. High-end features previously available only on enterprise level hardware are now accessible via Synology DS112+ to small and medium-sized businesses. DS112+ provides share-level AES 256-bit encryption to aid in the prevention of unauthorized access attempts to the hard drives.
Rich Office Applications
Synology DS112+ runs on the renowned operating system, Synology DiskStation Manager, (DSM) offering applications and features designed specifically for SMBs. Directory Server package turns Synology DS112+ into an LDAP-based directory server which is capable of centralizing the management and authentication of user accounts for different applications, therefore enhancing network security and reducing management costs.
Internet file access is simplified by FTP server and the web-based File Station. Synology DiskStation eliminates the requirement of advanced FTP knowledge for Internet file sharing. With just a few clicks, FTP service can be established. File Station provides easy file navigation on your DSM desktop, allowing you to move or copy files without installing any software on your client computer.
The built-in mail server offers a professional mail service and the USB printer sharing capability minimizes businesses’ cost by sharing printing resources throughout the office. VPN Server package offers an easy VPN solution that turns your DS112+ into a VPN server, providing a secure way of connecting to a private LAN at a remote location.
A backup wizard is provided for backing up data from DS112+ to another Synology DiskStation or any rsync server via an encrypted connection, or to an external hard drive via USB 3.0 or eSATA connection. The wizard also makes it easy to back up DiskStation data to the cloud via Amazon® S3. In addition, users can back up and restore DiskStation shared folders in multiple versions using Synology Time Backup package.
Shared Folder Sync allows users to synchronize a specific folder from Synology DS112+ to another DiskStation– a server-to-client backup mechanism that takes place whenever something is changed on the server side. Users will be able to share documents within their local office seamlessly and safely with encrypted connection. When your DiskStation is down, you will be able to have an immediate backup running in no time.
Energy Efficient with Cool and Quiet Design
Synology DS112+ is designed with energy efficiency in mind. Not only does it provide a larger fan and the smart airflow to keep the system running cool 24/7, its noise dampening design makes it really quiet (18.4 dB) compared to PC counterparts. The support of Wake on LAN/WAN, multiple scheduled power on/off and hard drive hibernation can further reduce power consumption and operation cost.
All Synology products are produced with RoHS compliant parts and packed with recyclable packing materials. Synology acknowledges the responsibility as a global citizen to continually work to reduce the environmental impact of every product produced.
Was £419.99 Inc. VAT
Only £339.95 inc VAT.
Save £80.04 inc VAT.
ORDER NOW
Synology Diskstation DS213 2-Bay Gigabit Ethernet Network Attached Storage - 6TB @ £429.95 inc VAT
2.0GHz Cpu frequency, 512MB Memory, XTB, 2X USB3.0, 1X USB2.0, 6TB Max HDD Support, 1X Gigabit LAN, Synology DiskStation Manager
Synology DS213 is a feature-rich 2-bay NAS server for workgroups & offices, for users who need to share and protect data cost-effectively
Key Features
Optimal Price/Performance Ratio
Effective Backup Solutions
Synology® DiskStation DS213 is a feature-rich 2-bay NAS server for workgroups and offices, specifically designed for users who need to share and protect data cost-effectively, while increasing productivity with comprehensive office applications.
Synology DS213 delivers an average 108.23 MB/sec reading speed under RAID 1 configuration in a Windows® environment, and 65.41 MB/sec writing1. DiskStation DS213 provides a reliable solution for data sharing with an easy to use interface, and comprehensive office applications, including a complete backup solution making it one of the best values in 2-bay NAS devices available today. Coming with USB 3.0 support which offers transmission speeds of up to 5 Gbps, namely 10 times faster than USB 2.0, DS213 takes less time for data transfer for external hard drives and consumes less power. In addition, hot-swappable drives make it easier for maintenance and hard drive replacement.
Synology DS213 offers a centralized backup target to consolidate fragmented and unstructured data across a network. PC users can back up their data to Synology DS213 using Synology Data Replicator software, and Mac OS X® users enjoy native Apple® Time Machine® integration. A backup wizard is provided for backing up data from DS213 to another Synology DiskStation or any rsync server via an encrypted connection, or to an external hard drive via USB 3.0 connection. The wizard also makes it easy to back up DiskStation data to the cloud via Amazon S3® or STRATO HiDrive. In addition, users can back up and restore DiskStation shared folders in multiple versions using Synology Time Backup package. Shared Folder Sync allows users to synchronize a specific folder from Synology DS213 to another DiskStation – a server-to-client backup mechanism that takes place whenever something is changed on the server side. Users will be able to share documents within their local office seamlessly and safely with encrypted connection. When your DiskStation is down, you will be able to have an immediate backup running in no time.
You can have your own cloud by using Cloud Station to freely access and sync file across different computers. Cloud Station keep multiple versions of a document in case of accidentally delete or upon any change.
Synology DiskStation DS213 runs on renowned multitasking operating system, the Synology DiskStation Manager (DSM). Offering a comprehensive list of business applications, the DS213 can be customized to run multiple applications of your choice to fulfill the requirement of your business environment. The DS213 replaces several pieces of traditional network hardware with rich features designed specifically for workgroups and offices such as antivirus, video surveillance, webmail, VPN, and LDAP directory services.
Applications are managed in the Package Center, an application portal that hosts applications as ready-to-use packages; to ensure high software integration as well as one-click-installation to eliminate guess work during installation. Additional approved 3rd party PHP web application such as content management, customer relationship management & e-commerce system can be hosted on DS213 by using Web Station with support for PHP/MySQL® web content.
Hassle-free System Installation
Web Assistant is a web-based utility to makes every DiskStation as easy to install as possible. Installation is done inside your existing web browser by setting up all vital system components in few simple steps. Combined with a quick start widget, users can simultaneously tour the DSM operating system and set it up to use right away.
The Synology DS213 is equipped with an encryption engine which offloads the encryption calculation task away from the main CPU, helping to improve file transfer speeds of the DiskStation.
Data protection is an important matter for businesses of all sizes. High-end features previously available only on enterprise level hardware are now accessible via Synology DS213 to small and medium-sized businesses. DS213 provides share-level AES 256-bit encryption to aid in the prevention of unauthorized access attempts to the hard drives.
Synology DS213 is designed with energy efficiency in mind. Not only does it provide a 92x92 mm fan and the smart airflow to keep the system running cool 24/7, its noise dampening design makes it really quiet compared to PC counterparts. The support of Wake on LAN/WAN, multiple scheduled power on/off and hard drive hibernation can further reduce power consumption and operation cost.
Package Content
DS213 Main Unit, Installation Disc, Welcome Note, Assembling Kit, AC Power Cord, AC Power Adapter, RJ-45 LAN Cable X1
Was £479.99 Inc. VAT
Only £429.95 inc VAT.
Save £50.04 inc VAT.
ORDER NOW
Key Features
High Performance
ORDER NOW
Key Features
Package Content
ORDER NOW
