- 10 Jan 2013
I recently added a second monitor to my setup, only to discover that it caused my memory clocks to permanently run at 1600MHz, pushing my idle temperatures up by around 15 degrees and causing my GPU fans to run faster and louder.
There's no reason for the memory clock to run that high while at idle/using 2D applications, yet I can't find a way to get it to clock down short of manually adjusting every time I'm not playing a game.
Anyone have any suggestions?
Your clocks for 120hz is normal 300/150 though.
