Does anyone @OCUK know when these boards are back in stock please.
On the 12th I was told 7-10 WD by OC.
The board is excellent.
My evidence is 8 out of the 9 awards at Computex Main event OC Competition, the most prestigious OC competition was using this board. Gigabyte took the other with the OC which in its price range truly excellent.
The M6E holds 32m, Pifast, 05,06,01 world records already!!! Mine can do DDR4000 easy!!! oh and 6.7ghz CPU!! with 5.9+ Uncore. DDR3200 on AIR!!!
As Kap points out TTL kicked me off that website for showing a customer a 3930K can indeed do 2400 mhz memory stable oh and infact I also showed them 2500+ Stable.
To cancel your order of the best Z87 board at the high end is mistake!!!
I have actually tried almost all the Z87 boards from all the manufacturers. The extreme is actually more compatible and less troublesome than almost all the rest and atleast equal to the best of them. If your a gamer and you want some easy clocking with multiple cards the Xtreme would still be my choice or the OC from Giga in the mid priced section.
I have tested all on air too so its a educated view even for non- LN2 clocking!!!
We have 20 boards arriving 28th/06/13 for the guys who asked!!!
Are we getting one?![]()
I keep thinking about it, benching a single card on Z87/4770k could be fun. I think a single watercooled Titan on this setup could be interesting. I don't think this setup is good for 3 or 4 GPUs though as the CPU speed is too low unless you are going to use exotic cooling.
Been toying with the same idea, I'm getting a Bench off Pgi.
Trying to decide between Haswell or a 3820/3930k set up![]()
If it's in addition to your other rig and using a single card, then Haswell all the way.
It would be
Just don't fancy the delidding of a Haswell
Then again, good excuse for a chiller![]()
I know this is slightly off topic but would an upgrade to my 7970 be any benefit to gaming (Skyrim, Flight Sim X) using 3 24" monitors?
Corsair 2800 is single sided MFR Hynix. Poor for tuning, great for frequency.
I thought it was a good review
I have a lot of time for TTL's reviews - I think in general hes more than fair
that plastic thing did look odd ... seems to add additional cost - to what worth ?
btw - this is from a Gene V owner (a motherboard I think is superb)
